Globe Dimensions: Veritas 350 & MEWA 351L
Discussion in 'Pressure Lamp Discussion Forum' started by Will, Jul 16, 2012.
  1. Will
    I am looking for glass globes for each of these lanterns. Could I have one of you measure an orignal globe and provide me with dimensions?
    Regards,
    Will
  2. David Shouksmith
    Can't help you with the Mewa, but I've a spare Veritas 350 globe you could have - PT me...
  3. WimVe
    MEWA like HASAG should be 120x120mm.
  4. WimVe
    Now I am confussed.
    I also need a Veritas 350 globe but looking at another Veritas 350 lantern I noticed that the marked Veritas France 120x120 globe doesn't fit right.
    It doesn't pass the rim in the base plate and sits therefore slightly higher.
    Can someone please measure an original blobe ?
    or is the tolerance off in the baseplate ?
  5. X246A
    Norfolk, England
    @WimVe
    I’ll check when I return to the Uk on Monday evening unless someone beats me to it.
    Regards Jeremy
  6. paul m
    paul m Subscriber
    lancashire. UK
    Veritas 350 is 12 cm x 12 cm
