11 Styles of Tilley TL10 etc., pumps.
Discussion in 'Tilley' started by JEFF JOHNSON, May 7, 2012.
  1. JEFF JOHNSON
    I have seen other variations and all going well I shall add any more which turn up, Jeff.
  2. fishfish
    i have one that seems to be a different size to the others i have,the seal doesnt seem to fit ie the place it goes is bigger than the others,will i need to make a seal do you think?(the one on the far right)
    I had not seen your post until now and making a seal should cure the problem.
    Jeff
    Do you know when, and on what lamps, the pump with the raised “printing” was used (2nd photo, second from left).
    @JEFF JOHNSON
    Hello Tony, the answer is no, because Tilleys from all periods turn up with a variety of pumps fitted and some may have been replacements.
    This link shows more variations of Tilley pumps, just scroll down the page.
    Tilley PL56
