1936 Duo-Lite and Reflector
Discussion in 'Other/Unidentified' started by Colin M, Sep 25, 2012.
  1. Colin M
    Not often seen
    The Coleman Duo Lite and Reflector.
    Lantern 242C June 1949
    Turns an Outdoor Lantern into an Indoor Lamp.
    Colin
    Very smart! :thumbup:
  3. Jean J
    How cool is that!
  4. Wim
    Wim Subscriber
    Dendermonde, Belgium
    Jolly good idea! I like it :D/
    Best regards,
    Wim
  5. Matthew92
    Matthew92 Subscriber
    Looks good, is that base ceramic?
  6. Colin M
    Base is pressed metal, one good reason why not many survived. This one is in good nick, must have been indoors.
    I wish the base was ceramic
    Colin
  7. dmacp
    dmacp United States Subscriber
    Altadena, California USA
    I thought the duo lite had a special shade attachment that screwed into the top of the lantern-the threaded hole being in the crimped vent insert?
    Dan
  8. Colin M
    Pretty sure you are right Dan, I looked at the one on Terry's site and this appears to be the case.
    I guess I will have to throw this one in the scrap metal bin as it's incomplete.
    [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X
    Colin
  9. dmacp
    No offence intended, Colin. A friend and I have been researching the various combinations of the duo-lite. There was a ceramic base on the USA version. quite rare. I think you are using yours exactly as Coleman intended. To mount the parchment shade you would need an early 242 lantern, which had a threaded receptacle and a stud with a ball nut, all mounted in the center of the ventilator.
    I saw one of the Canadian ones on ebay recently. It went for several thousand US dollars.
    Best wishes,
    Dan
  10. dmacp
    Actually I should update this, as the Coleman 242 series were all made to accept a shade on the vent stud with the finial screwed down on top of it. I have pamphlets of Duo-Lite combinations that might not have existed. And hardware that exists but is not in the pamphlet.
  11. Norman
    Spokane, WA
    What a great find.
    Thanks for sharing.
    Norman
