Some of you may be aware that I am currently working on a project to compile a list of all Coleman Gas Appliance part numbers and part names. Currently working on stoves and lanterns (do you know that there appears to be thousands of part numbers for lamps and "non-camp" stoves). Due to this the current focus is on lanterns and camp stoves. My goal is to hopefully make sense of changing parts names and numbers over time. Even with the narrow scope of just lanterns and stove, this seems to be, at present, an endless task. So, I decided to refocus for a while and tackle something I think is a bit easier and might actually get finished before I depart this planet. Right now, I have decided to try the same thing with Thermos lanterns and stoves. There is much small number of models. About 25 stoves and 20 lanterns. And a lot of these models are mostly the same with just the change from separate pump and filler to the combined filler/pump. So far i have instructions only for the following: Lantern Thermos 8312 Lantern Thermos 8319 Lantern Thermos 8326 Stove Thermos 8491 Stove Thermos 8423 Stove Thermos 8427 So, I would be very grateful if anyone had any other Instructions for any of the other stoves or lanterns. I can promise not to distribute!! Since I run OCR on the files to extract the part numbers and names, when done I can return the files and/or delete my copy if you wish. Of course, I will give credit to the source! Thanks Kevin
