are the generators interchangeable on these models? the lamps look the same, just wondering if you can swap generators to run the lamp on different fuel??
@swiss-paul Yes, since the 339 was designed for kerosene and the fuel pickup in the tank is probably, although I have never taken one apart, not set up for instalight, therefore you will most likely need a preheat cup no matter what fuel you are using. The 335 on the other hand will need a preheat cup for kerosene. I just undid such a conversion since I don't normally use kero. Mike
