Does a Coleman 135, 136 lamp exist?
Discussion in 'Pressure Lamp Discussion Forum' started by hikerduane, Nov 1, 2022.
  1. hikerduane
    I see in the Reference Gallery that there is a slot for these, but no entries. Do these models exist? I got a call from my radio ad request regarding my WTB lanterns, lamps, guy said he had a Coleman 135A. Different make or a wickie?
    Duane
  2. Toby Garner
    SW Missouri
    I'm thinking the 135 was an export?.. maybe I'm thinking something else...
    Neil McRae (@Mackburner) has the 135 and 136 listed as "export" in the Pressure Lamp Catalogue:
    135 as "Kerosene export R55 generator, 2 pint Silvertone fount, Pyrex globe, parchment shade. 1937
    136 as "Kerosene export t-44K generator, 2 pint Coppertone fount, Pyrex globe, parchment shade. 1937".
  4. hikerduane
    Thank you very much, item is local to me. I'll see if I can look at it Thursday after a road trip for roofing material.
    Duane
  5. Mackburner
    Yes both are listed in a 15th March 1937 Coleman Export catalogue. They are pretty much the same as model 168K but with T44 roto type generator and I assume a kero burner. I'm sorry but I can't illustrate this as I don't have permission from the catalogue owner. I see there is a mistake in the PLC entry as I show both with incorrect generators. The catalogue clearly states both 135 & 136 use a T44 (118C299) generator and not the R55 or T44K I list. The only difference is the finish 135 is Silvertone and 136 is Coppertone. I have no idea what the A version might be so will be very interested to see this one. ::Neil::
  6. hikerduane
    Thank you, the seller said it still has the decal, plus fuel. :) He was no help with other details other than the cream color Coleman used, hope to get it Thursday afternoon. I have three other Coleman lamps the same color.
    Duane
  7. Mackburner
    Sounds like it might just be the colour change and the A is cream. Be good to see if it is which will add a line to the PLC at least. ::Neil::
  8. hikerduane
    Looks like a 132A, been trying to make it look like a 135A, but took a photo and number curves like a 2 and not a 5.
    Duane
  9. Mackburner
    OK then we get to dial down the excitement then. A pity because to date I don't know of one with an collector. ::Neil::
  10. hikerduane
    Guess it would have been too much to ask in a small community. Did find a Perfection oven in good shape at a thrift store I visited.
    Duane
  11. Tony Press
    Well, at least we were able to sort out a more accurate description of the 135 and 136. :thumbup:
  12. Toby Garner
    SW Missouri
    Bummer Duane... For what it's worth those 132A's are excellent runners :)
  13. hikerduane
    Cleaning up parts, lye bath for the interior, tons of crud rinsed out before the lye. :( Messed up a bit of the paint around the fuel bung. :(
    Picked up a couple Coleman 242's the same day, failed to note one had a crushed fount slightly as the collar exposes a gap and now see the other had a couple deep rust pits to the fount bottom, I only saw the other day the rusty bottom, not the deep pits. Something to do for a couple days getting these running, keeps me off the streets.
    Duane
