Fuel not coming through yet, only air.
Discussion in 'Fettling Forum' started by Lighthouse, Jun 17, 2013.
  1. Lighthouse
    Lighthouse Subscriber
    sunny & slightly less cold south coast, sweden
    Just like the title says, what is the solution to my problem. Fuel is not coming out of the nozzle when pressurised ... there are no leaks... the bottom is just dented a little, even tho nothing too serious. However, when almost full, the fuel comes out nice, but as soon as there's less fuel in the tank air is getting out of the nozzle.
    Everything's air tight, generator is cleaned, new nozzle and needle.
    Thanks.
  2. Graham P Australia
    Albury area NSW AUstralia
    You will have to tell make model etc and photo`s help a lot.
    Graham P
  3. Shed-Man R.I.P.
    As Graham says, it is difficult to assess without model type and preferably some pictures. However, if you get fuel flow when it is full, but not when the fuel level is lower, it may be a pick-up tube problem. Empty the tank and with a torch see if you can see the pick-up tube. It may have become detached, been shortened or even be just at the wrong angle. Pics needed mate. Steve.
  4. Nils Stephenson
    Just like Steve says, it sounds like the fuel tube is either broken off half way or has a hole in it.
    It would be nice to know what sort of lamp it is though. :)
  5. norf
    If its a coleman its a problem with the pickup for the fuel as the air pickup hole is clear,,,,hopefully its not one of the plastic pickups....
  6. Mackburner
    Clairvoyant we ain’t so make and model please. Has to be a fuel tube leak. Some are an easy fettle and some are a bear so we really do need to know what the lamp is.
    ::Neil::
  7. Lighthouse
    Thanks for all the replies so far... Should have mentioned make before, it's a Primus 992 we are talking about here (basically the same as the 991 lantern version). Once the fuel is past a certain level, air comes out first, followed by a ''plop'' and fuel comes out. This repeats itself untill only air comes out.
    A leak in the pick-up tube sounds right to me.
    /frank
  8. Mackburner
    Has to be. I can't remember dismantling a 992 but you should be able to unscrew the valve block from the tank and pull out the whole fuel feed. I a not sure if 992 has a foot valve or not but either way it is a simple enough fettle to either repair or replace the small tube. The lamp will work fine without a foot valve so if there is one you don't have to re fit it. ::Neil::
  9. Nils Stephenson
    Not that easy actually as the valve block is soldered in place. Should be possible though and is actually a job I need to do on a 1081 so please keep me posted on progress. :)
  10. Mackburner
    Ah I was not sure about that. I know some Primus stuff is soldered in. Sometimes that was done before the base plate was inserted and just unsoldering will not permit removal. Not a job I have had to do on a Primus so I don't know. Be interesting to find out. ::Neil::
