Fuel oil leaking around pump
Discussion in 'Pressure Lamp Discussion Forum' started by Clyde Boyd, Jun 17, 2018.
  1. Clyde Boyd
    Clyde Boyd Subscriber
    After testing my TL120 which I just finished rebuilding, I noticed a lot of fuel around the base of the lamp. Upon further investigation I noted the fuel was coming from the pump stem. When I removed the pump, the pump assembly was full of fuel. Anyone have any ideas. Thanks in advance.
    Clyde
    The most likely cause is that seal in the non return valve needs to be replaced.
  3. Clyde Boyd
    Thanks Jeff. I presume you mean the one located in the bottom of the pump.
    Yes, that is correct.
