High Temperature Electronics Tape
Discussion in 'Pressure Lamp Discussion Forum' started by isfuzzy, Sep 1, 2020.
  1. isfuzzy
    Singapore
    I am waiting for Fred to reply me on the mica chimney. i had an order for a 327. But for now, i do still have the tired original mica chimney on my lamp. The mica has chips, cracks and pieces wanting to fall off. While watching some guys repairing some PCBs, i noticed they used a yellowish tape. Kapton tape.
    Kapton Tape Adhesive High Temperature Heat Resistant Polyimide 5~50mm BGA .jpg
    Used for electronics for the most part. It stands heat of around 300 degrees C.. A soldering iron resting on the tape doesn't do anything to it, and is still as sticky after that. SO......
    It is yellow alright, very yellow. But i think it doesn't really matter when its lit up. No physical changes too.
    Perhaps some of you will end up making art from it and paste it on glass? :lol:
  2. MYN
    Kapton's fine. Its used for some higher temperature rated electric motors as well. Insulation sheets inside the windings. As long as it holds and doesn't peel off, I think it wouldn't matter much.
  3. george
    Why not just replace the damaged pieces of mica? :-k
  4. WimVe
    I would not tape the two pieces, top, bottom half, together.
