Hipolito 502 Fount problem
Discussion in 'Fettling Forum' started by Siatbury, Oct 24, 2015.
  1. Siatbury
    Hi all
    I've got a Hipolito 502 which leaks at the point where the lower vapouriser screws into the fount.I have found that the chrome threaded piece which receives the vapouriser and lead washer is not bedding down - thread is gone I fear. Is there any practical solution or has the fount had its day? Obviously if the vapouriser can't be secured into the fount the whole lamp is U/S....
    Siatbury
  2. James
    James Subscriber
    You could try wrapping some PTFE tape around the threads to see if that seals up the leak.
