Lantern lighter?
Discussion in 'Pressure Lamp Discussion Forum' started by Krisse, Dec 4, 2020.
  1. Krisse
    Sweden
    Has anyone managed to find a candle lighter that is narrow and long enough to work for lanterns with small holes?
  2. MYN
    How small?
  3. WimVe
    You may also consider a creme brulee burner. They have a long spiky flame.
  4. Krisse
    Sweden
    as thin as possible. Thinner than standard lighter
  5. MYN
    Nope. Haven't found any that is as thin as you would like. I'm looking for one too. I know what you mean.
  6. Martin K.
    Martin K. Subscriber
    A match?
  7. Krisse
    Sweden
    Yes, that's the obvious I use now
  8. Wim
    Wim Subscriber
    Dendermonde, Belgium
    For very little money you can buy wicks for candle making at Aliexpress ( type 'candle making' in their search engine). They come in many different lenghts.
    @Krisse
  9. Blueflame Canada
    Montreal Canada
    Google "pencil torch" , butane, refillable.....usually very cheap from China.
  10. george
    What about a standard long kitchen match? That's all I've ever used and they always seem to work. Don't confuse them with regular pipe matches, they are too short.
  11. podbros
  12. MYN
    I have a lighter (the one at the bottom in the picture below), that should be slightly thinner than the one in the picture you posted earlier, @Krisse .
    I know you would like something with a tube that's at least as thin as the one shown on top of the lighter.
  13. WimVe
    You can dismantle a standard lighter. The only thing to work out is the piezo lighting.
    The gas is in a small tube.
  14. bp4willi
  15. Toby Garner
    SW Missouri
  16. Buggerlugs
    What about one of these, will that help you?
  17. podbros
    @bp4willi
    @Buggerlugs .. They both look useful :thumbup: :thumbup:
    Have you gents tried both of these??
    It would be good to have pics of them in use/ being used if you could?
    I have seen something similar to willi’s fire stick.. my mum had one, it was silver or silver plate a proper antique
  18. Tony Press
    Those flint lighters that @Buggerlugs posted aren’t called “WHOOMP-STICKS” for nothing…
    I’ve got a few, New Old Stock, that I’ll never put on a lamp or lantern.
    I use a long twisted brass wire with a wick bound in the end. Soak it in metho, light it and use it as a wick lighter. It’s safe, warms the generator, and eliminates the annoying flare up that Coleman lanterns and lamps are prone to.
    I will post a photo tomorrow.
  19. bp4willi
  20. podbros
    Thanks @bp4willi :thumbup:
    They look useful.. is that one of your methods?
  21. bp4willi
    Use it preferred for candles. But would suit for Lanterns too.
