Leaking pump
Discussion in 'Fettling Forum' started by scudo, Oct 10, 2022.
  1. scudo United Kingdom
    uk
    Bladon blowtorch, I have pre heated, pressurised it and it works, however there is leakage in the pump, checked with soapy water and also appears to be sucking paraffin back in to the pump tube.
    I have replaced the cork`pip` with a viton `pip` which appears to be perfectly flat so in theory should be sealing ok.
    Should the viton be softened in some way?
    What else can I do to try and sort this?
  2. Henry Plews
    Viton is slightly firmer than cork so will need a stronger spring to make it seal correctly. Try stretching the existing spring a little, if that doesn't work you may have to adapt the spring from a ball point pen.
  3. ROBBO55
    Check that the surface it seals against is clean and there is no damage or scratches.
  4. scudo United Kingdom
    uk
    Martin, the surface appears to be ok.
    Henry, I will try another spring and see if that works.
  5. hikerduane
    Some pips are not punched out "squarely".
    Duane
  6. presscall
    Lancashire, UK
    The two plane surfaces must be parallel (‘square’) if the pip’s been punched out of sheet of uniform thickness surely @hikerduane
    John
  7. scudo United Kingdom
    uk
    I have played around with the spring and rebuilt, I gave a doz or so pumps and lit it, it maintained pressure for several minutes, just used it to burn some driveway weeds.
    There still appears to be a slight leak on the non return valve even though its working ok.
    I will leave for now and next obtain some cork and redo the pip and see if that helps.
  8. Fireexit1 United Kingdom
    I have found that some Viton is harder than others, as well has had some very odd shapes created on the sides while punching out my own. Sounds like you are on the right track, but you might find something of the right diameter at the fettlebox
  9. scudo United Kingdom
    uk
    This has been a good learning curve for me as I have several `paraffin` items from 30+ years and were stored in the attic, I have today brought them out and will start to bring them back to working order.
    My priority will be a lantern , dish heater and a camping stove just to cover my back for any energy cuts this Winter.
