Missing part?
Discussion in 'Pressure Lamp Discussion Forum' started by frlrubett, Feb 10, 2022.
  1. frlrubett United States
    London
    If you don’t have a wicked spirit dish that fits over the vapouriser, you can use lighting torch like the Tilley one, or similar.
    Check out the Reference Gallery for these Table Lamps.
  3. frlrubett United States
    London
    This is advertised as a Bialladin, but I cannot see anything in the reference gallery which is the same. It looks like a T20 base.
  4. podbros
    Hi there
    Going by the picture you posted it has been made up from different lamp and lantern parts
    The base is from a Bialaddin lantern.. you can just make out where the screw fittings are on the top of the tank .. the column looks to be from a Tilley table lamp with the control tap from an x246a and the vapouriser and burner Tilley as well
    I believe the gallery is made by the seller..
    It all looks very well made to me :thumbup:
    @frlrubett @Tony Press
    Edit* I didn’t look at the control tap very well! :doh:It’s off a bialaddin as well so I’m only guessing what the burner and vapouriser are off!
  5. Rickylee United Kingdom
    Chesterfield
    It's mine once again, it's all bialaddin running gear (vap/c.cock/burner) the brass stem is Tilley and so is the glass (repro182).
