My First Petromax burning nicely..
Discussion in 'Lamp Action Gallery' started by a10egress, Mar 17, 2019.
  1. a10egress
    a10egress United States Subscriber
    After 15 years or more of Coleman, this is my first Petromax, a 829.
  2. Henry Plews
    Nice images. Completely different to the Coleman's which you're used to, I'm sure you'll come to appreciate this type of lantern.
    Henry.
  3. a10egress
    Oh, this Petromax has caused me a few new cuss words :p but in the end it turned out to be my fault for not preheating it enough...
    They are well built lanterns!:thumbup:
  5. Reinhard
    Reinhard Germany Subscriber
    Congratulations on your first Petromax.:thumbup:
    I see there is still snow there.
    You have to preheat for at least 90 seconds with the Rapid or alternatively with two bowls of spirit.
    Regards Reinhard
  6. ROBBO55
    Congratulations @a10egress it's cleaned up beautifuly. :thumbup:
  7. Sellig33
    Sellig33 France Subscriber
    The alternative is better and softer for the mantle, and also more fun :D/
    I start all my lamps like this ( Petromax, Optimus, Hipolito, Tilley, Bialaddin & Vapalux )
  8. a10egress
    So you all preheat with 2 bowls of spirit and as the second bowl is about 1/2 gone, start pumping but leave valve closed until spirit is nearly all consumed and then open valve?
  9. Carlsson
    I never do it that way.
    If it's not much below freezing where you are, one full cup should absolutely be sufficient, but there are variations in lanterns there. And never with any pressure in the lantern at all until just before the meths is about to expire and it's time to light the mantle. Then you close the vent screw and start to pump.
    I can just aswell quote Phil from another topic, because that's the way to do it:
    If you use an in-built pre-heating torch, it's a totallay different story, of course.
  10. WimVe
    Nice lantern !
    Is it marked with a Greatz only ?
    If so give her a matching globe.
  11. a10egress
    G only marked and an original globe is something I am on the hunt for...
  12. WimVe
    Well it was common before Pelam took over the brand that lanterns where sold with an E&G marked globe.
    Now I am writing this I wonder if I even ahve seen only G marked globes.
