Part no. 90 lead washer replacement
Discussion in 'Fettling Forum' started by Jelopascua, Jul 3, 2013.
  1. Jelopascua
    Hi anyone knows what size/number of the viton O-rings are used as a replacement for the lead washer for the generator to the fount.
  2. Carlsson
    Which lamp?
  3. Nils Stephenson
    I think I have heard of someone trying to use rubber as a replacement for the lead washer but I don't think it was very successful. Lead is the best option for that joint. It does mean you can't undo and tighten again, so alignment the first time is important.
  4. Carlsson
    Ah. I guess it was for an Optimus then.
  5. John
    John United States Subscriber
    Dallas, Texas; United States
    I'd say Optimus or similar Petromax and clones. I find that modern lead gaskets are just a bit thin so I'm looking for a thicker solution. I'm kinda a purist so lead it will be.
  6. spiritburner
    spiritburner Admin
    N.E. England
    The Fettlebox (me) is adding this to the shop soon. They are 2mm thick lead. If anyone needs any before they go in the shop drop me a PT.
  7. John
    I'm good for right now Ross but thanks for bringing them in.
  8. Jelopascua
    How much would that cost me to be shipped in the philippines?
  9. Nils Stephenson
    I make my own from lead sheeting I found at the scrap metal dealer. All you need is a good hole punch set. It is only a bit over 1mm thick so sometimes I have to use two. Having 2mm ones in the Fettlebox sounds good Ross.
  10. spiritburner
    spiritburner Admin
    N.E. England
    They will be 45p with the CPl discount code in the Trading Post - Postage to UK/Europe is £1 & £1.38 everywhere else. That will cover around 8 washers.
