Pressurising Donut Tilleys
Discussion in 'Pressure Lamp Discussion Forum' started by Tom_Tilley83, Jul 11, 2024.
  1. Tom_Tilley83
    Tom_Tilley83 United Kingdom Subscriber
    Malvern, Worcestershire, uk
    Hi Everyone
    Does anyone know how you go about pressurising donut tilley lamps?
    I've got an OL50 and an IL47 and neither came with a pump.
    I'm presuming you need to adapt the pump to use a usual type X246 pump or use a bike pump??
    Thanks Tom
    Those lamps were originally fitted with a pressure valve / filler cap and a bike pump with a connection was used to pressurise the tank.
    1930s IL-33 (300cp).
  3. WimVe
    If your lamps do have the original filler cap you should use a bike pump with hose.
  4. Mackburner
    The filler incorporates a check valve and has a cycle pump fitting. Like this from my IL47 which is more or less the same for all the do-Nut lamps. ::Neil::
  5. Dean D
    Dean D Subscriber
    Minnesota USA
    I went to a bicycle shop and bought a hand pump for the European style tubes. Works well with a flexible rubber hose.
  6. Tom_Tilley83
    Thanks Neil, both mine have their original fitting caps
  7. Tom_Tilley83
    Cheers Dean. I'll look out for one
  8. Tom_Tilley83
    Yes mine have them
