Replacement fount for AGM 2 mantle 3718 lantern?
Discussion in 'Pressure Lamp Discussion Forum' started by hikerduane, Jun 21, 2023.
  1. hikerduane
    Anyone know offhand which model lantern fount would be the same as the AGM 3718? I can seal the two lower stress cracks and run some sealant over the couple other cracks and use kero instead of gas. Trying to free up the pricker mechanism now. Pump may need a newer spring as the new pip does not hold, allowing pump shaft to rise. Original globe. :)
    Duane
  2. hikerduane
    Good luck I guess. Only one in the Lamp Gallery. Hopefully the sealer I use will "take". Been trying to dry out the fount all day, out in the sun and close to my wood stove. Pricker is loose, it was the pricker shaft that was stuck, hardest thing to loosen was the genny nut of all things. Bent burner tube broke off before I could unscrew it very far, but was lucky that using my little pinkie I was able to unscrew the remaining bit in the mixing chamber. Friend is shortening a burner tube to replace the broken one.
    Duane
