Tilley gas lamp
Discussion in 'Open Forum' started by Francisc Masec, Oct 30, 2022.
  1. Francisc Masec Netherlands
    Sweden
    Hi people!
    I was expecting a Sievert but i got a Tilley. I don't find so much of information, i managed to find a picture of the top.
    Is the topp possible to find?
    Because the guard is similar to the X246 i will probably try to find a top from that to protect the mantle.
    The glass is bigger that the one for optimus 300 but smaller than primus 1020.
    The tank it is a Sievert what i hade as reserv. ( it was mounted on a Sievert tank, i askef the seller to dismantle it because it's nearly impossible to ship a gas tank)
    Any ideas?
    Cheers,
    Francisc
    IMG_20221028_191704.jpg IMG_20221028_191726.jpg IMG_20221028_192447.jpg IMG_20221028_200424.jpg IMG_20221028_200533_1.jpg
    This is the only image i found on google.
  2. ROBBO55
  3. podbros
    Tilley did some gas lamps with multicoloured tops as well but I’m not sure what they are called?
    This one with Hendon on may be earlier than ‘69?
    did it come with the gas still in the tank at all? Does it look like there is a way of refilling it?
    Certainly looks very bright.
  4. podbros
    Ok I found the thread and I was wrong about the top being for this lamp :doh:
    The thread is called…
  5. Francisc Masec Netherlands
    Sweden
    @podbros the tank is mine but is was dismantled from a similar Sievert tank.
    Cheers,
    Francisc
  7. Francisc Masec Netherlands
    Sweden
    Thanks @JEFF JOHNSON! I looked through all the catalogues on the site.
    On another listing is just the cage and is similar, it's under the name of 562P. I didn't found any other reference to that number.
    Cheers, Francisc
  8. Francisc Masec Netherlands
    Sweden
    @ROBBO55 thanks, but i don't think it's a 602T. The legs goes out on 602, on mine goes in like on x246B but not so much.
    Cheers,
    Francisc
