Tilley heater mesh globe
Discussion in 'Pressure Lamp Discussion Forum' started by Darryl Durdin, Apr 12, 2022.
  1. Darryl Durdin
    Hi fellas, where can I sources two mesh globes for my Tilley 22, or being the practical minded fella that I am can I make them.
  3. Fireexit1 United Kingdom
    I think that they are the same as the R1 burner. I got my last one on eBay UK but hopefully there will be some closer to home.
  4. Sedgman
    Victoria, Australia
    Some have been made from two welch plugs for ends and stainless wire. They work quite well. Business in Braidwood sold or sells them. I reckon you could make a couple. They have straight sides; not bulging.
  5. Tony Press
  6. Fireexit1 United Kingdom
    That looks a much better design than the original. The Bialaddin heater element always seems to me to be more robust and put out more heat than the Tilley one. Depends on your desire to stick to original shape I guess, bearing in mind the original was asbestos not metal so already a change.
  7. Rangie
    I believe someone was doing stainless mantles for them.
    Maybe too early to tell how they will handle the heat cycling but it may be worth a try?
    Alec.
  8. ROBBO55
  9. Darryl Durdin
    Thank you everyone for you input, I’m going with the local Australian made from Braidwood, I will make one as I have a few Tilley heaters to fettle.
