Tilley Lamp Instructions
Discussion in 'Pressure Lamp Discussion Forum' started by nrogerson, Nov 28, 2013.
  1. nrogerson
    Hi All,
    Does anyone have an electronic copy of the tilley X246B instructions that are included in the box? I cant seem to find mine anywhere and wanted to give a friend a copy. A link to an online version will do if thats easier and i can print it off from there. Thanks in advance, Neil
  2. norf
    hi,
    its in the lamp reference library,its in the Tilley section.
  3. David Shouksmith
    Only if you're a subscriber, though...
    Failing that, I wouldn't have thought a quick Google for 'Tilley instructions' or similar would be beyond most...
    Edit: Yep, worked first time... :whistle:
  4. nrogerson
    Perhaps its just me but i did try searching for Tilley Instructions on google, base-camp had some and so did a few other websites as well as numerous youtube vids but i was hoping for a scan of the original Tilley instructions. I'll keep looking, thanks
  5. David Shouksmith
    Yes, it was the Base-Camp ones that I arrived at via Startpage (=Google more-or-less).
    The X246B ones (specifically) aren't in the Reference library. Just about every other Tilley product is though and as you'll be aware, they'll all apply to the X246B.
    Maybe someone has a spare set they could supply you - Heaven knows, they must be common enough...
  6. Shed-Man R.I.P.
    I have an original copy of the 246B instruction sheet spare. PT me if you would like it.
    Steve.
