Tilley Lamp, left un-used
Discussion in 'Pressure Lamp Discussion Forum' started by JonasRiis, Dec 7, 2021.
  1. JonasRiis Denmark
    Denmark
    Hello! Beeing new to this Forum, I hope to acquire some knowledge.
    A couple of years ago, I bought a Tilley X246B from the Danish "Army-shop". It appeared to be relatively un-used and looked good too!
    However, it wouldn't burn properly, with a lot of flames outside the mantle so i've now decided to change the vapourizer and all of the washers. A quick question. When leaving the tilley after use, do you release the pump? I've once released the pressure and tightened the pump again with the control knob "off" but the day after it had pressurised itself a bit (Leaving a mess of Kerosene on my desk). What do you do :)
    I always leave the pump on a Tilley unscrewed after I have released the pressure.
  3. ROBBO55
  4. JonasRiis Denmark
    Denmark
    Thank you so much!
    Looking forward to get her going!
  5. Buggerlugs
    In my opinion its always safer to leave the pump released and unscrewed.
  6. AussiePete
    Yes, I too after use, release the pressure and leave the pump loose to prevent any build up of pressure in the fount/tank.
  7. Alenstein Poland
    Ełk
    Welcome on the board Jonas, safer is not holding pressure in the lamp...
  8. Tom Pedersen
    Denmark
