Tilley X246B blown tank re-use suggestions
Discussion in 'Pressure Lamp Discussion Forum' started by ColinG, Dec 14, 2017.
  1. ColinG United Kingdom
    I've just replaced a blown '83 tank with a cleaned up '73 tank and it works so much better! It came from a dear old lady who gave me two Tilleys for free, one 246A and the other a 246B. The A is still waiting to be fettled and the cage is pretty rusty but I'll do what I can.
    Anyway, that leaves me with a 246B tank that isn't worth doing anything with... or is it? I have enough bits and pieces to make an electrified table lamp 'conversation piece' but do I really want to? I see them on eBay and they make me cringe.
    What else can you do with them apart from keep keeping them on a shelf taking up space?
    Make some sort of camping stove with one? A plant pot maybe?
  2. phaedrus42
    You could make a Primus stove out of one as the stove requires much less pressure.
  3. ColinG United Kingdom
    I could do that... I guess I'd just need to fix a burner to the top of the font as a first step.
  5. ColinG United Kingdom
    Oooooh, that would be doable, or something similar.
  6. Matthew92
    Matthew92 Subscriber
    I'll admit to having electrified a Bialaddin that had a cracked tank, I could still salvage all the parts that are good and the tank would still be as scrap as it was before. It makes for a nice bedside lamp and is far more pleasing to look at than something modern.
    The alternative is to stick it in a box and when you need some brass to repair another lamp, you can cut it up. :thumbup: If you go to the trouble of converting a tank to take a stove burner, you might as well start with a sound tank. Make up an adapter, so it all screws together.
  7. ColinG United Kingdom
    True... and all the work to create a stove I don't really need. I think electrification will be the final outcome.
  8. JEFF JOHNSON
    The base plates from blown X246B tanks make decent reflectors and they can be unsoldered easily.
    Then drill a hole in the middle and either polish the brass or paint them with silver paint, the polished brass gives a gold tint to the light.
  9. David Shouksmith
    Save yourself the clart-on of any of those suggestions and take it to the nearest scrapyard - the brass was worth £1 and that was years ago. It's gotta be worth much more these days...
  10. ColinG United Kingdom
    I think I'll message it into an electric lamp for my eldest son. He loves things like this.
  11. broadgage
    North Somerset
    You could simply store the damaged tank, one day you might come across a 246B with a good tank but with other major components missing or defective.
    I found a little used X246B that had suffered severe rust to the hood, the vapouriser, and the frame, replacing these components would have cost as much as a new lamp.
    One good lamp made out of two, at little expense.
