Too much stuff what to keep
Discussion in 'Pressure Lamp Discussion Forum' started by winchman, Jun 9, 2013.
  1. winchman
    I have very little room.
    I have a perfect Chrome tilly.
    I have a Vapolux in need of restoration The one the army use made in England, just needs a clean up really so which should I get rid of and why?
    I think the Vapolux? if so what should I ask?
  2. fouloleron2002
    I would keep the vapalux personally.
  3. Shed-Man R.I.P.
    I'd chuck out something else [-X and keep them both :-$ . Steve.
  4. Derek
    I agree with Steve. One lamp does not constitute a great saving in space. But if push came to shove - keep the Vapalux.
  5. loco7lamp
    loco7lamp Subscriber
    Put some large screw in cup hooks in the garage roof beams & keep both , two lamps are no more bother than one :D :thumbup:
    Wait untill you get to this stage :doh:
    This is when you need to worry ](*,) :doh: :whistle: , don't even mention the stoves & blowlamps :doh: ](*,) :D :thumbup:
    Stu :D :thumbup:
  6. winchman
    So why should I keep the Vapolux?
    I understand what you arte all saying but I just kept my chrome tilly for power cuts etc and I like it.
    The vapolux has a mark on the glass looks like its been hot is this ok to use?
  7. Shed-Man R.I.P.
    As I said earlier, better to keep both of them. If you only have two lamps you don't have a big storage problem (two lamps hanging up take up about 0.5m square space) If I had to get shot of one, it would be the Tilley, because the vapalux is so much superior quality. No contest - in my opinion. But, I would keep both of them!
  8. JEFF JOHNSON
    The mark on the Vapalux glass will probably have been caused by the lantern being used with a damaged mantle.
    I have found that so long as an undamaged mantle is used then a marked glass will be okay.
    Damaged mantles direct the heat to one spot and if the problem is not noticed quickly then the glass will break, Jeff.
