Vapalux 300x cage problems
Discussion in 'Fettling Forum' started by Stuey, Apr 28, 2014.
  1. Stuey
    Hi all,
    Just wondering if anybody else has had the problem where the cage supports come away from the mount?
    I've seem this now on a couple of 300x's but I've also noticed it's not so much of a problem on the later cages as they changed from a riveted type to a screw in type.
    So has anybody else had this problem and if so how did you fix it? My initial thoughts are to remove the offending upright support and replace with a later one from 305.
    Regards
    Stu
    That is a common problem and it may be possible to replace the rivets, but I have not tried it, Jeff.
