Vapalux, Halifax
Discussion in 'Pressure Lamp Discussion Forum' started by Darryl Durdin, Nov 3, 2021.
  1. Darryl Durdin
    Hi fellas, I have a Vapalux that has Halifax ? On the hood any information
  2. Martin K.
    Martin K. Subscriber
  3. Darryl Durdin
    @Martin K. thank you for the lead,
    Could not see for looking
  4. Gary Waller
    @Darryl Durdin Vapalux lamps where manufactured in Halifax, West Yorkshire, hence they put Halifax on some of the hoods, I’m guessing your hood is from a Vapalux 300.
  5. ColinG United Kingdom
    We need a photo mate!
  6. Darryl Durdin
    Here’s a picture of my valpalux halifax DBEAC713-5AB9-4143-88A7-1D8C65FEDA59.jpeg
  7. JEFF JOHNSON
    A fine fettling project.:thumbup:
  8. Gary Waller
    Vapalux 300, steel tank. Probably from 1945, have a close look is there a date on the hood..
    Should be fairly straightforward to get it going.
  9. ROBBO55
    It should clean up nicely, Darryl :thumbup:
  10. M.Meijer
    Netherlands
    It has the (new) collar with one triangled hole, replacing the multi-slotted ones in the end of 1944. This also means you do not have to dig for a holed glass and can settle for more common ones. Around this (war-) time similar 300 model Vapa's appeared without any marks (no embossing) in the ventilator but usually with a crowsfoot and year stamped into the lower brass rim. That enamelled top looks clean from here, and these are nice lamps to use if you can control the rust.
  11. Alenstein Poland
    Ełk
    Try to find Ian Ashton's book about Vapalux, everything is explained, this is made after June 1944 or in 1945...
  12. David Shouksmith
  13. Darryl Durdin
    Thank you fellas
