Veritas - Generator’s Pricker Replacement
Discussion in 'Fettling Forum' started by AussiePete, Jan 6, 2020.
  1. AussiePete
    @Damien
    I think you meant Martin (@ROBBO55).
    By the way, you’re heading to my home country...
  3. Damien Australia
    NSW
    Thanks Pete... and Martin and Tony and Darryl... the list just keeps growing! I'll get some of those assorted tubes and the appropriate dies.... Blackwoods here we come!
  4. Roy Allan New Zealand
    New Zealand
    Great work and pics to show the process,does the assembly need lapping in to shut off fuel? I’m getting everything together to do this thanks to your efforts here.I bought acupuncture needles which fit the jet nicely and waiting on the brass tube. And 2mm die
  5. Henry Plews
    The needle assembly is for cleaning the jet only. There is a seperate control for fuel off/on.
  6. ColinG United Kingdom
    Hi Pete, I can't see how it happened but I somehow missed your kind offer! I checked and they have a different product offering but essentially, I would very much like you to get some tube for me so I can begin creating Veritas prickers.
    This looks like the closest replacement with sufficient wall thickness no take a thread. The other 1/16 brass tube has a very thin wall thickness.
    Colin
  7. Henry Plews
  8. ColinG United Kingdom
    I have 2mm brass tube but the difference between this and 1/16 inch is significant. 1/16th inch is 1.5875mm - enough to stop me doing what I wanted. I might try Kennions as they seem to stock imperial sizes locally.
  9. Roy Allan New Zealand
    New Zealand
    I used 2mm tube and .75mm to slip into it. I bought a box of acupuncture needles .015 a small flat file was handy to cut a ring around the tubes and snap and nail clippers for the wire.
  10. ColinG United Kingdom
    Roy, that sounds interesting, could you explain in more detail? If you had photos that would be even better. Thanks.
  11. Darryl Durdin
    @Roy Allan , can you please share some pictures of your handy work. Others are interested, making pricker needles is not so easy for some. You need to be resourceful some times with what you have.
