Wingnuts for Tilley FL6
Discussion in 'Open Forum' started by Paraffin Paddy, Apr 20, 2025.
  1. Paraffin Paddy United Kingdom
    middlesbrough
    hi apologies if this isn't allowed in this part of the forum if its not allowed please delete.
    anyway i'm just wondering if anyone has any FL6 Wingnuts for sale? thank you
  4. ROBBO55
  5. Paraffin Paddy United Kingdom
    middlesbrough
    thank you for welcomes,much appreciated,but basecamp dont stock them.any other ideas?
  6. Sedgman
    Victoria, Australia
    Tough task. Perhaps get threaded rod matching the Tilley part and have large BSW wing nuts welded onto the rod ends; or get fully remade wingnuts.
  7. Paraffin Paddy United Kingdom
    middlesbrough
    Thankyou Sedgman,that might be my only option
  8. Fireexit1 United Kingdom
    There are BSW wing nuts in EBay. Not quite like the originals but should get you going.
  9. ROBBO55
    @Paraffin Paddy
    I have measured the threads on two of mine and get 3/8" x 20 TPI which is a British Standard Fine thread.
  10. Sedgman
    Victoria, Australia
    Agree with @ROBBO55 on the thread spec which is why I said ‘get threaded rod matching the Tilley part’ and then weld on a large wing nut that is still available such as 3/8" BSW. The thread needs to be that finer spec to get it tightened more easily.
    I also said ‘tough task’ because it’s not easy and BSF parts are much harder to get hold of.
    Another option is to drill out the thread in the yoke and use a bolt and nut. A wing nut might do in a pinch but you probably can’t tighten it by hand enough to stabilise the floodlight from rotation. The Tilley wing bolts are quite large and make it easier to tighten.
    I would suggest @Paraffin Paddy you hold out and keep looking for two proper wing bolts. Often these missing pieces turn up in the most unexpected ways.
  11. podbros
    There seem to be a few options available on ebay uk ranging from
    £3.50 and upwards for 2 off x 1 + a half 3/8” bsf
    which might be good for an idea of where to start.. longer threads and different sizes there as well..
    regards
    pb
  12. Paraffin Paddy United Kingdom
    middlesbrough
    thanks for the info,podbros.but i think i`m going to hold on until i can get hold of an original pair
  13. podbros
    no worries ;-)
  14. Paraffin Paddy United Kingdom
    middlesbrough
    i managed to get myself some wing nuts for the fl6 they were free but the lamp they came with wasn't.
    £167 later...
  15. Sammi Jane
    Sammi Jane Subscriber
    Aberdeen, Scotland
    Ah, you've caught the lampitis bug then... :lol:
  16. Paraffin Paddy United Kingdom
    middlesbrough
    They dont call me Paraffin Paddy for nothing !!
  17. Paraffin Paddy United Kingdom
    middlesbrough
    By the way,the doctor said i`m riddled with it
  18. Sammi Jane
    Aberdeen, Scotland
    Don't worry. I think that we've all got it..! :lol:
  19. Paraffin Paddy United Kingdom
    middlesbrough
    Hmm i dont think ill over it .I dont think my wallet will either
  20. David Shouksmith
    Unfortunately there's no known cure either. I thought I was in remission after 10 years or so but it seems I'm having a serious relapse now after rescuing a pretty little X246 Guardsman from a charity shop recently.
    LA (Lampaholics Anonymous) helped but you just take one little sip and you're back to square one if you're not careful... :doh: ](*,) :whistle:
  21. Paraffin Paddy United Kingdom
    middlesbrough
    Ah well,if its terminal i suppose ive got to keep on collecting them until i kick the bucket
